vcMaterial
Material is a material used by geometry and solid shapes in the 3D world.
Referenced by: vcAnnotation.Material, vcApplication.Materials, vcApplication.createMaterial(), vcApplication.findMaterial(), ... (see more)
vcBooleanFeature.Material
vcCollisionDetector.CollisionMaterial
vcCollisionDetector.NodeACollisionMaterial
vcCollisionDetector.NodeBCollisionMaterial
vcComponent.Material
vcDimension.Material
vcExtrudeFeature.Material
vcGeometrySet.Material
vcMaterialProperty.Value
vcNode.NodeMaterial
vcPrimitiveFeature.Material
vcRevolveFeature.Material
vcSetNodeMaterialStatement.Material
vcSweptVolume.Material
vcVolumeSensor.VolumeMaterial
| Ambient | vcColor | RW | Defines a vector used for calculating the ambient value of the material. |
| ColorMask | vcMaterialColorMaskFlags | RW | Defines the RGB/RGBA color mask used for rendering the material. |
| DepthComparison | vcMaterialDepthComparison | RW | Controls the visibility of geometry See moreassigned to the material based on pixel depth (distance from camera) in comparison to a Z-axis buffer. |
| Diffuse | vcColor | RW | Defines a vector used for calculating diffuse reflection of light hitting the material. |
| Name | String | RW | Gets the name of the material. |
| Opacity | Real | RW | Gets or sets the opacity value of the material (1 is fully opaque, 0 is fully transparent). |
| OpacityType | vcMaterialOpacityType | RW | Gets or sets the opacity type used by the material. |
| RenderOrder | vcMaterialRenderOrder | RW | Defines the order in which geometry using this material is rendered in the 3D world. |
| Shininess | Real | RW | Defines the intensity of the light that's reflected from the material, thereby defining its luster. |
| Specular | vcColor | RW | Defines a vector used for calculating the specular reflection of the light hitting the material. |
| Texture | vcBitmap | RW | Gets or sets the bitmap defining the texture of the material. |
Example: Inherit and Render Material
''' vcMaterial: Inherit and render material Please test component with multiple nodes, such as a six-axis articulated robot ''' import vcCore as vc app = vc.getApplication() comp = vc.getComponent() async def OnRun(): red_matte = app.findMaterial("red_matte") while True: comp.MaterialInheritance = vc.vcMaterialInheritance.DISABLED await vc.delay(1.0) comp.MaterialInheritance = vc.vcMaterialInheritance.FORCE_INHERIT_LEVEL comp.NodeMaterial = red_matte await vc.delay(1.0) comp.MaterialInheritance = vc.vcMaterialInheritance.FORCE_INHERIT_NODE comp.NodeMaterial = red_matte await vc.delay(1.0)
Example: Set Material Opacity
''' vcMaterial: Set material opacity ''' import vcCore as vc import vcFeatures as vc_fea vc_ft = vc_fea.vcFeatureType app = vc.getApplication() comp = vc.getComponent() def create_block(): block = comp.findFeature("Block") if not block: block = comp.RootFeature.create(vc_ft.BLOCK, "Block") comp.rebuild() def get_material(material_name): material = app.findMaterial(material_name) if not material: material = app.createMaterial(material_name) material.OpacityType = vc.vcMaterialOpacityType.CONSTANT return material async def OnRun(): create_block() material = get_material("MyMaterial") material.Ambient = vc.vcColor(1.0, 0.0, 0.0) material.Opacity = 1.0 while True: for level_index in range(256): level = 1.0 - level_index * (1.0 / 256.0) material.Opacity = level comp.Material = material await vc.delay(0.01) for level_index in range(256): level = level_index * (1.0 / 256.0) material.Opacity = level comp.Material = material await vc.delay(0.01)
